필요한 것
Place laptop upside down.
Rotate so the battery side is facing away from you.
Locate the twelve screws on the bottom of the laptop.
Using the correct Phillips head screwdriver remove the twelve screws from the bottom of the laptop.
Locate the wires that connect the screen to the laptops body. (They are located at the bottom left side of the screen.)
Lift up the black protective cover that the wires lie under.
With one hand holding the black cover up, with free hand carefully pull away the wires, removing them from the laptop’s body.
다른 2명이 해당 안내서를 완성하였습니다.
