소개
This guide will go through the steps needed to install the laptop's RAM.
  1. Turn the computer over onto its back.
    • Turn the computer over onto its back.
  2. Slide the lock on the left side to the unlock position. Slide the lock on the right side to the unlock position until there is a clicking sound.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the battery by sliding it out while both locks remain in the unlock position. Remove the battery by sliding it out while both locks remain in the unlock position.
    • Remove the battery by sliding it out while both locks remain in the unlock position.
  5. Turn the computer over onto the back. Use a Phillips head screwdriver to remove the screw holding the RAM cover in place, and lift the cover. One 4.0 mm coarse thread screw.
    • Turn the computer over onto the back.
    • Use a Phillips head screwdriver to remove the screw holding the RAM cover in place, and lift the cover.
    • One 4.0 mm coarse thread screw.
  6. Use a plastic opening tool to open the silver flaps on either side of the RAM. Once both flaps are released, the RAM should pop up at an angle. Once both flaps are released, the RAM should pop up at an angle.
    • Use a plastic opening tool to open the silver flaps on either side of the RAM.
    • Once both flaps are released, the RAM should pop up at an angle.
  7. Grasp both sides of the RAM and pull to remove it. Grasp both sides of the RAM and pull to remove it.
    • Grasp both sides of the RAM and pull to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alison Wendt
회원 가입일: 2013년 04월 18일
78 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G51
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 938
