소개
This guide will go through the steps needed to install a new wireless card.
  1. Turn the computer over onto its back.
    • Turn the computer over onto its back.
  2. Slide the lock on the left side to the unlock position. Slide the lock on the right side to the unlock position until there is a clicking sound.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the battery by sliding it out while both locks remain in the unlock position. Remove the battery by sliding it out while both locks remain in the unlock position.
    • Remove the battery by sliding it out while both locks remain in the unlock position.
  5. Turn the computer onto the back. Remove the Phillips #0 screw that secures the cover to the rest of the device. One 5.1 mm coarse thread screw.
    • Turn the computer onto the back.
    • Remove the Phillips #0 screw that secures the cover to the rest of the device.
    • One 5.1 mm coarse thread screw.
    • Pull the cover forward to release it.
  6. Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card. Two 4.0 mm coarse thread screws. Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
    • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
    • Two 4.0 mm coarse thread screws.
    • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  7. Hold the edges of the wireless card and carefully disconnect the black 3 pin connector. Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
    • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
결론
Alison Wendt
회원 가입일: 2013년 04월 18일
78 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G51
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 592
