주요 콘텐츠로 건너뛰기
Toshiba Portege M400 CD/DVD Drive Replacement
필요한 것
  1. Toshiba Portege M400 CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1/1
    • Make sure your computer is securely latched and closed.
    • Locate the CD drive on the right side of your Toshiba Portege M400 laptop and find a small hole right next to the CD drive button.
  2. Toshiba Portege M400 CD/DVD Drive Replacement: 2 단계, 이미지 1/2 Toshiba Portege M400 CD/DVD Drive Replacement: 2 단계, 이미지 2/2
    • Using the tweezers, insert them into the small hole next to the CD drive button.
  3. Toshiba Portege M400 CD/DVD Drive Replacement: 3 단계, 이미지 1/2 Toshiba Portege M400 CD/DVD Drive Replacement: 3 단계, 이미지 2/2
    • Push the tweezers back into the hole and grab the CD drive door with the other tweezers' appendage.
    • Pull the CD door out carefully to remove the broken or jammed disk.
    • Note: If the CD door still does not open, move on to the next step to see how to remove the CD drive entirely.
  4. Toshiba Portege M400 CD/DVD Drive Replacement: 4 단계, 이미지 1/1
    • Flip the laptop over so its on its face.
  5. Toshiba Portege M400 CD/DVD Drive Replacement: 5 단계, 이미지 1/3 Toshiba Portege M400 CD/DVD Drive Replacement: 5 단계, 이미지 2/3 Toshiba Portege M400 CD/DVD Drive Replacement: 5 단계, 이미지 3/3
    • Locate screw as seen on picture
    • Using #1 Philips head screwdriver remove the 3.8mm screw.
  6. Toshiba Portege M400 CD/DVD Drive Replacement: 6 단계, 이미지 1/2 Toshiba Portege M400 CD/DVD Drive Replacement: 6 단계, 이미지 2/2
    • Locate the lock switch in the center of the laptop.
    • Locate the tab on the end of the end of the CD Drive.
  7. Toshiba Portege M400 CD/DVD Drive Replacement: 7 단계, 이미지 1/3 Toshiba Portege M400 CD/DVD Drive Replacement: 7 단계, 이미지 2/3 Toshiba Portege M400 CD/DVD Drive Replacement: 7 단계, 이미지 3/3
    • Push down on the lock tab and pull on the CD tab simultaneously.
    • Keep pulling on the CD drive tab until the CD drive comes all the way out.
결론
Spencer Dilley
회원 가입일: 04/15/13
4 평판
안내서 1개 작성함
Cal Poly, Team 4-17, Maness Fall 2012 Cal Poly, Team 4-17, Maness Fall 2012 회원
CPSU-MANESS-F12S4G17
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,093
