이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In this guide, you will learn how to disassemble the broken/damaged keyboard from the rest of the laptop as well as how to replace it. This guide will also teach you what the proper and necessary tools are for this repair.
필요한 것
Remove the front face plate with a plastic opening tool.
Use a #1 Phillips screwdriver to unscrew and remove the two 3.8mm screws labeled B3.
다른 한 분이 해당 안내서를 완성하였습니다.
