주요 콘텐츠로 건너뛰기
Toshiba Portege M400 Motherboard Replacement
필요한 것
  1. Toshiba Portege M400 Motherboard  Replacement, Motherboard: 1 단계, 이미지 1/1
    • Using the plastic opening tool, remove the plastic hinge cover on the back of the laptop. Use caution not to damage this plastic cover.
  2. Toshiba Portege M400 Motherboard  Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, remove the plastic cover directly above the keyboard. Make sure to start from the corners of the plastic cover.
  3. Toshiba Portege M400 Motherboard  Replacement: 3 단계, 이미지 1/1
    • Using the #1 Phillips head screwdriver, remove the two 3.8mm screws.
  4. Toshiba Portege M400 Motherboard  Replacement: 4 단계, 이미지 1/1
    • Remove the keyboard, make sure you gently remove any ribbon cables holding it to the rest of the computer. Bending or crimping a ribbon cable can break the device.
  5. Toshiba Portege M400 Motherboard  Replacement: 5 단계, 이미지 1/2 Toshiba Portege M400 Motherboard  Replacement: 5 단계, 이미지 2/2
    • Use a small phillips screwdriver to remove both metal shields as depicted.
  6. Toshiba Portege M400 Motherboard  Replacement: 6 단계, 이미지 1/2 Toshiba Portege M400 Motherboard  Replacement: 6 단계, 이미지 2/2
    • After removing the second metal covering you will remove the RAM compartment.
    • Simply pull apart the metal fasteners on the side; the RAM should pop out for removal.
  7. Toshiba Portege M400 Motherboard  Replacement: 7 단계, 이미지 1/3 Toshiba Portege M400 Motherboard  Replacement: 7 단계, 이미지 2/3 Toshiba Portege M400 Motherboard  Replacement: 7 단계, 이미지 3/3
    • Disconnect the wire from the exposed wireless card.
    • Pry open the top of the laptop and gently remove and disconnect the wires as shown.
  8. Toshiba Portege M400 Motherboard  Replacement: 8 단계, 이미지 1/2 Toshiba Portege M400 Motherboard  Replacement: 8 단계, 이미지 2/2
    • Remove the screws attaching the motherboard to the plastic housing.
    • Lift off the motherboard. Once it is free of screws and you're done!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dustin
회원 가입일: 03/12/14
1,213 평판
안내서 6개 작성하였습니다
University of Maryland, Team 6-2, Vijaybhaskar Spring 2014 University of Maryland, Team 6-2, Vijaybhaskar Spring 2014 회원
UMD-VIJAYBHASKAR-S14S6G2
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,240
