주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
  1. Using a plastic opening tool, remove all stickers covering the screws. Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
    • Using a plastic opening tool, remove all stickers covering the screws.
    • Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
  2. Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver. Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
    • Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
  3. With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop. Slowly pull the plastic panel from the entire laptop.
    • With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
    • Slowly pull the plastic panel from the entire laptop.
  4. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  5. Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen. Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
    • Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
  6. Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings. Remove all white tape that hold the cords and wirings together.
    • Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings.
    • Remove all white tape that hold the cords and wirings together.
  7. Note: Some parts need unplugging. Slowly and carefully unplug each of the components. Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
    • Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
  8. At this point, the screen should be completely disconnected from the rest of the laptop.
    • At this point, the screen should be completely disconnected from the rest of the laptop.
결론
Varsha Roopreddy
회원 가입일: 2013년 04월 19일
1 평판
안내서 4개 작성하였습니다
Cal Poly, Team 4-17, Maness Spring 2013 Cal Poly, Team 4-17, Maness Spring 2013 회원
CPSU-MANESS-S13S4G17
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,160
