소개
In this guide, you will learn how to disassemble and reassemble your Toshiba Portege laptop to replace a broken touchpad.
필요한 것
Remove the front face plate with a plastic opening tool.
Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
Use a plastic opening tool to carefully remove the cover of the touchpad.
Remove the one 1/2" inch screw on the backside of the laptop.
거의 끝나갑니다!
결론
