주요 콘텐츠로 건너뛰기
Toshiba Portege M400 Touchpad Replacement
필요한 것
  1. Toshiba Portege M400 Touchpad Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Touchpad Replacement: 2 단계, 이미지 1/1
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Touchpad Replacement: 3 단계, 이미지 1/3 Toshiba Portege M400 Touchpad Replacement: 3 단계, 이미지 2/3 Toshiba Portege M400 Touchpad Replacement: 3 단계, 이미지 3/3
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Touchpad Replacement: 4 단계, 이미지 1/2 Toshiba Portege M400 Touchpad Replacement: 4 단계, 이미지 2/2
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
  5. Toshiba Portege M400 Touchpad Replacement, Touchpad: 5 단계, 이미지 1/2 Toshiba Portege M400 Touchpad Replacement, Touchpad: 5 단계, 이미지 2/2
    • Use a plastic opening tool to carefully remove the cover of the touchpad.
    • Remove the one 1/2" inch screw on the backside of the laptop.
  6. Toshiba Portege M400 Touchpad Replacement: 6 단계, 이미지 1/2 Toshiba Portege M400 Touchpad Replacement: 6 단계, 이미지 2/2
    • Gently pull up the touch-pad piece and lay it upside down.
    • The touch-pad will still be connected to the computer.
  7. Toshiba Portege M400 Touchpad Replacement: 7 단계, 이미지 1/2 Toshiba Portege M400 Touchpad Replacement: 7 단계, 이미지 2/2
    • Pull back the tab to disconnect the touchpad to the laptop.
결론
Varsha Roopreddy
회원 가입일: 04/19/13
37 평판
안내서 4개 작성하였습니다
Cal Poly, Team 4-17, Maness Spring 2013 Cal Poly, Team 4-17, Maness Spring 2013 회원
CPSU-MANESS-S13S4G17
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,133
