주요 콘텐츠로 건너뛰기
Toshiba Portege R205-S209 Heatsink Fan Replacement
필요한 것
  1. Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: 1 단계, 이미지 1/3 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: 1 단계, 이미지 2/3 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: 1 단계, 이미지 3/3
    • With the laptop flipped over, unlock the mechanism that is shown in red.
    • Lift and remove the battery out of the device.
  2. Toshiba Portege R205-S209 Heatsink Fan Replacement: 2 단계, 이미지 1/2 Toshiba Portege R205-S209 Heatsink Fan Replacement: 2 단계, 이미지 2/2
    • Remove the accessory plate by unscrewing the single Phillips #0 screw and lifting up the panel.
  3. Toshiba Portege R205-S209 Heatsink Fan Replacement: 3 단계, 이미지 1/3 Toshiba Portege R205-S209 Heatsink Fan Replacement: 3 단계, 이미지 2/3 Toshiba Portege R205-S209 Heatsink Fan Replacement: 3 단계, 이미지 3/3
    • Remove the 18 Phillips #0 screws that keep the bottom plate attached to the outer portion of the laptop.
  4. Toshiba Portege R205-S209 Heatsink Fan Replacement: 4 단계, 이미지 1/3 Toshiba Portege R205-S209 Heatsink Fan Replacement: 4 단계, 이미지 2/3 Toshiba Portege R205-S209 Heatsink Fan Replacement: 4 단계, 이미지 3/3
    • Remove the 2 Phillips #0 screws holding the heat sink in place.
    • Detach the heatsink fan from the motherboard by removing the clip that connects them together and pulling away from the laptop horizontally.
결론
Jason Sizen
회원 가입일: 04/04/19
193 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G2, Crossman Spring 2019 IUPUI, Team S1-G2, Crossman Spring 2019 회원
IUPUI-CROSSMAN-S19S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 150
