주요 콘텐츠로 건너뛰기
Toshiba Portege R205-S209 Keyboard Replacement
필요한 것
  1. Toshiba Portege R205-S209 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
  2. Toshiba Portege R205-S209 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the locking mechanism to the right and hold.
  3. Toshiba Portege R205-S209 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the locking mechanism to the right, insert your finger into the tab and lift up.
  4. Toshiba Portege R205-S209 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove battery by lifting upward.
  5. Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
  6. Toshiba Portege R205-S209 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the display.
  7. Toshiba Portege R205-S209 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Portege R205-S209 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the plastic casing above the keyboard with the plastic opening tool. Start at the edges of the plastic casing and move toward the middle.
  8. Toshiba Portege R205-S209 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Lift up and remove the plastic casing.
  9. Toshiba Portege R205-S209 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the 4mm Phillips head screws at the top of the keyboard at both ends, using the Phillips head #00 screwdriver.
  10. Toshiba Portege R205-S209 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Lift up the keyboard, but do not remove it completely.
    • The keyboard is still attached to the computer, so be very careful when lifting it up.
  11. Toshiba Portege R205-S209 Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Portege R205-S209 Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Gently pull the ribbon toward the screen until it slides out of the connecting point.
    • Remove keyboard.
결론
Leah Catania
회원 가입일: 10/12/15
113 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 451
