소개
In this guide we will be dissembling the device so that we can replace the fan in the laptop.
  1. Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Pull up on the back casing and remove it.
    • Pull up on the back casing and remove it.
  5. Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  6. Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
결론
JRJones
회원 가입일: 2013년 04월 19일
121 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 회원
CPSU-MANESS-S13S2G19
3 회원들
안내서 5개 작성하였습니다
Don't forget the silver compound when re-assembling
Graham Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 3,032
