주요 콘텐츠로 건너뛰기
Toshiba Portege R500 Wi-FI Card Replacement
필요한 것
  1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Portege R500 Wi-FI Card Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Wi-FI Card Replacement, Wi-FI Card: 2 단계, 이미지 1/1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Wi-FI Card Replacement: 3 단계, 이미지 1/1
    • Pull up on the back casing and remove it, revealing the Wi-Fi card.
  4. Toshiba Portege R500 Wi-FI Card Replacement: 4 단계, 이미지 1/2 Toshiba Portege R500 Wi-FI Card Replacement: 4 단계, 이미지 2/2
    • Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
    • Pull the Wi-Fi card towards the battery slot to release it.
  5. Toshiba Portege R500 Wi-FI Card Replacement: 5 단계, 이미지 1/1
    • Remove the three wires from the Wi-Fi card by pulling them straight up and off.
    • The Wi-Fi card should now be free of the laptop.
    • When removing the wires be sure to remember which wire came from which port, consider marking them so that you can remember.
결론
JRJones
회원 가입일: 04/19/13
169 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-19, Maness Spring 2013 Cal Poly, Team 2-19, Maness Spring 2013 회원
CPSU-MANESS-S13S2G19
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 1,295
