주요 콘텐츠로 건너뛰기
Toshiba Portege R700-S1312 Fan Replacement
필요한 것
  1. Toshiba Portege R700-S1312 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Fan Replacement: 2 단계, 이미지 1/1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Fan Replacement: 3 단계, 이미지 1/3 Toshiba Portege R700-S1312 Fan Replacement: 3 단계, 이미지 2/3 Toshiba Portege R700-S1312 Fan Replacement: 3 단계, 이미지 3/3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Begin by removing 14 70mm screws from the back cover of the laptop using a Phillips #00 Screwdriver. Do not attempt to remove the back cover just yet though.
  5. Toshiba Portege R700-S1312 Fan Replacement: 5 단계, 이미지 1/1
    • Next, using a Phillips #00 Screwdriver unscrew 2 40mm screws from the RAM cover, and remove the RAM cover.
  6. Toshiba Portege R700-S1312 Fan Replacement: 6 단계, 이미지 1/1
    • Next, unscrew 2 40mm screws using a Phillips #00 Screwdriver. The back cover will now be able to be removed with greater ease. Note the previously covered 70mm screw illustrated by a red circle on the image.
  7. Toshiba Portege R700-S1312 Fan Replacement: 7 단계, 이미지 1/2 Toshiba Portege R700-S1312 Fan Replacement: 7 단계, 이미지 2/2
    • The back cover of the laptop can now be removed by gently lifting its edges with your hands. Avoid abrupt removal of the back cover because it is attached internally. Move the cover to the side and the fan will now be visible.
  8. Toshiba Portege R700-S1312 Fan Replacement: 8 단계, 이미지 1/2 Toshiba Portege R700-S1312 Fan Replacement: 8 단계, 이미지 2/2
    • Remove the two 50mm screws holding down the fan using a Phillips #00 screwdriver.
  9. Toshiba Portege R700-S1312 Fan Replacement: 9 단계, 이미지 1/1
    • Disconnect the fan's power cables from the motherboard by gently pulling the white connector towards the fan and away from the motherboard.
  10. Toshiba Portege R700-S1312 Fan Replacement: 10 단계, 이미지 1/1
    • You can now safely remove the fan completely and replace it with your replacement fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Terail Clonts
회원 가입일: 09/14/16
125 평판
안내서 1개 작성함
Western Carolina University, Team 1-4, Virtue Fall 2016 Western Carolina University, Team 1-4, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G4
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,539
