주요 콘텐츠로 건너뛰기
Toshiba Portege R700-S1312 Hard Drive Replacement
필요한 것
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Portege R700-S1312 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Portege R700-S1312 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Francisco Vilchis
회원 가입일: 09/12/16
234 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-4, Virtue Fall 2016 Western Carolina University, Team 1-4, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G4
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 2,501
