주요 콘텐츠로 건너뛰기
Toshiba Portege R700-S1312 RAM Replacement
필요한 것
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: 2 단계, 이미지 1/1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Portege R700-S1312 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Portege R700-S1312 RAM Replacement: 3 단계, 이미지 3/3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: 6 단계, 이미지 1/1
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: 7 단계, 이미지 1/1
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: 8 단계, 이미지 1/1
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: 9 단계, 이미지 1/1
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
결론
To reassemble your device, simply follow steps 1-3 in reverse order.
Francisco Vilchis
회원 가입일: 09/12/16
234 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-4, Virtue Fall 2016 Western Carolina University, Team 1-4, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G4
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 506
