소개
This guide will show you how to replace the RAM in a Toshiba Portege R705-P35 laptop. The RAM should be replaced if the computer has memory issues which may be the case if the computer won’t boot or runs slowly. Be sure to remove and re-insert at a 45 degree angle. When replacing, the white side clips should snap back into place when the new board is inserted.
필요한 것
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
