주요 콘텐츠로 건너뛰기
Toshiba Portege R705-P35 Wi-Fi Card Replacement
필요한 것
  1. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 2 단계, 이미지 1개 중 1개
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: 4 단계, 이미지 3개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: 4 단계, 이미지 3개 중 2개 Toshiba Portege R705-P35 Wi-Fi Card Replacement, RAM Plate: 4 단계, 이미지 3개 중 3개
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Hard Drive Plate: 5 단계, 이미지 1개 중 1개
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Back Plate: 7 단계, 이미지 1개 중 1개
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement: 8 단계, 이미지 2개 중 2개
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 Wi-Fi Card Replacement, Wi-Fi Card: 11 단계, 이미지 1개 중 1개
    • Use your fingers to disconnect the white and black cords from the Wi-Fi card.
  12. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the two 3 mm screws from the Wi-Fi card using a Phillips #00 screwdriver.
  13. Toshiba Portege R705-P35 Wi-Fi Card Replacement: 13 단계, 이미지 2개 중 1개 Toshiba Portege R705-P35 Wi-Fi Card Replacement: 13 단계, 이미지 2개 중 2개
    • Pull the Wi-Fi card out of the laptop at a 45° angle.
결론
작성자
2다른 기여자 명과 함께
Kathryn Hockenbury
회원 가입일: 03/23/22
833 평판
안내서 8개를 작성함
UMass Dartmouth, Team 1-4, Botvin Spring 2022 UMass Dartmouth, Team 1-4, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G4
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 406
