주요 콘텐츠로 건너뛰기
Toshiba Portege R835-P56X Speaker Replacement
필요한 것
  1. Toshiba Portege R835-P56X Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Turn laptop with the back cover facing up .
    • Make sure the laptop is unplugged and powered off before beginning.
  2. Toshiba Portege R835-P56X Speaker Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Unlock the clips by pulling towards the unlock.
  3. Toshiba Portege R835-P56X Speaker Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Portege R835-P56X Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Holding the unlock clips push the battery away from the laptop.
  4. Toshiba Portege R835-P56X Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screws from the back of the laptop
    • you should have removed 18 screws, make sure to keep these in a safe place as you will need them for reassembly.
  5. Toshiba Portege R835-P56X Speaker Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Using the blue prying plastic tool remove the back cover.
  6. Toshiba Portege R835-P56X Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the screws from the fan and side ports
  7. Toshiba Portege R835-P56X Speaker Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Portege R835-P56X Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the white and orange cables attached by pulling out the cables
  8. Toshiba Portege R835-P56X Speaker Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • locate the speakers
    • Gently lift the motherboard to release the speaker cables
  9. Toshiba Portege R835-P56X Speaker Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, gently remove the tape being used to hold down the speaker cables.
  10. Toshiba Portege R835-P56X Speaker Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Portege R835-P56X Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Once the cable had been released you have successfully removed the speakers!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anay Sanchez
회원 가입일: 09/20/17
494 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 8
전체 시간: 438
