주요 콘텐츠로 건너뛰기
Toshiba Portege R835-P88 Cooling Fan Replacement
필요한 것
  1. Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/3 Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 2/3 Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 3/3
    • Shut down the computer and unplug.
    • Unlock and remove battery.
  2. Toshiba Portege R835-P88 Cooling Fan Replacement: 2 단계, 이미지 1/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 2 단계, 이미지 2/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Remove the three small covers from the bottom by removing two 11mm screws and three 5mm screws using a screwdriver #J000.
    • Remove the remaining screws from the bottom cover using phillips head screwdriver #PH00.
  3. Toshiba Portege R835-P88 Cooling Fan Replacement: 3 단계, 이미지 1/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 3 단계, 이미지 2/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Pry the bottom cover using blue plastic ifixit prying tool.
    • Lift up and remove cover.
  4. Toshiba Portege R835-P88 Cooling Fan Replacement: 4 단계, 이미지 1/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 4 단계, 이미지 2/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Disconnect the fan cable from the motherboard.
    • Remove two 3mm screws from fan using #J000 phillips head screwdriver.
    • Lift up and remove fan.
  5. Toshiba Portege R835-P88 Cooling Fan Replacement: 5 단계, 이미지 1/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 5 단계, 이미지 2/3 Toshiba Portege R835-P88 Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Replace the fan.
    • Assemble the Toshiba Portege R835-P88 following all disassembly steps in the reverse direction.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kimberly Fowler
회원 가입일: 01/18/17
141 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 10
전체 시간: 1,194
