주요 콘텐츠로 건너뛰기
Toshiba Portege R835-P88 Optical Drive Replacement
필요한 것
  1. Toshiba Portege R835-P88 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Start by removing the battery.
  2. Toshiba Portege R835-P88 Optical Drive Replacement: 2 단계, 이미지 1/2 Toshiba Portege R835-P88 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Start by removing the back cover by removing the screws, revealing the Optical Drive. Remove the 1 cm screws to remove. Then use the spudger to pry the back off.
  3. Toshiba Portege R835-P88 Optical Drive Replacement: 3 단계, 이미지 1/1
    • After the cover is removed, remove the screws that hold the Drive. It has 3, 1 cm screws holding it down.
  4. Toshiba Portege R835-P88 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Take the 2, .5 cm screws out of the drive line. Once this is complete, you have successfully taken out the Optical Drive.
결론
Colt Cates
회원 가입일: 01/19/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 664
