주요 콘텐츠로 건너뛰기
Toshiba Portege R835-P88 Screen Replacement
필요한 것
  1. Toshiba Portege R835-P88 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove the battery by pressing the two buttons inward and pulling the battery out.
  2. Toshiba Portege R835-P88 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the end caps located on the left and right corners below the screen.
  3. Toshiba Portege R835-P88 Screen Replacement: 3 단계, 이미지 1/1
    • Remove the square rubber caps on top of the screws
    • Remove the 4 mm screws at the top
    • remove the two 6 mm screws that were under the chrome caps at the bottom.
  4. Toshiba Portege R835-P88 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the plastic bezel by lightly prying on it. It will pop when it starts to come loose.
  5. Toshiba Portege R835-P88 Screen Replacement: 5 단계, 이미지 1/2 Toshiba Portege R835-P88 Screen Replacement: 5 단계, 이미지 2/2
    • Remove tape from around cord attached to the bottom of the screen.
    • Place the screen on top of the keyboard
  6. Toshiba Portege R835-P88 Screen Replacement: 6 단계, 이미지 1/3 Toshiba Portege R835-P88 Screen Replacement: 6 단계, 이미지 2/3 Toshiba Portege R835-P88 Screen Replacement: 6 단계, 이미지 3/3
    • Remove the cord from the screen by cutting the tape where the two fittings meet. After that pull them apart.
결론
Madison Crawford
회원 가입일: 01/19/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 5
전체 시간: 446
