주요 콘텐츠로 건너뛰기
Toshiba Qosmio X305-Q704 Screen Replacement
필요한 것
  1. Toshiba Qosmio X305-Q704 Screen Replacement, Keyboard: 1 단계, 이미지 1/1
    • Find an edge of the red strip along the edge the computer and pry it off using a spudger.
  2. Toshiba Qosmio X305-Q704 Screen Replacement: 2 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement: 2 단계, 이미지 2/2
    • Find an edge of the black cover piece around the keyboard and pry it up using the spudger.
  3. Toshiba Qosmio X305-Q704 Screen Replacement: 3 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement: 3 단계, 이미지 2/2
    • Lift the keyboard up and detach the strip connecting the keyboard to the back of the laptop.
  4. Toshiba Qosmio X305-Q704 Screen Replacement: 4 단계, 이미지 1/3 Toshiba Qosmio X305-Q704 Screen Replacement: 4 단계, 이미지 2/3 Toshiba Qosmio X305-Q704 Screen Replacement: 4 단계, 이미지 3/3
    • Remove the keyboard from the Laptop.
  5. Toshiba Qosmio X305-Q704 Screen Replacement, Screen: 5 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement, Screen: 5 단계, 이미지 2/2
    • Unscrew the four 10 mm screws with the Phillips #0 screwdriver.
  6. Toshiba Qosmio X305-Q704 Screen Replacement: 6 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement: 6 단계, 이미지 2/2
    • Insert the iFixit opening tool into the side of the computer that separates the top and bottom of the laptop. Move the tool along the edge of the laptop until the cover can be separated from the device.
    • Do not remove the panel from the device, as you'll need to disconnect cables before the component can be fully removed.
  7. Toshiba Qosmio X305-Q704 Screen Replacement: 7 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement: 7 단계, 이미지 2/2
    • Disconnect all wires connecting the top piece to the bottom.
  8. Toshiba Qosmio X305-Q704 Screen Replacement: 8 단계, 이미지 1/3 Toshiba Qosmio X305-Q704 Screen Replacement: 8 단계, 이미지 2/3 Toshiba Qosmio X305-Q704 Screen Replacement: 8 단계, 이미지 3/3
    • Disconnect all wires connecting the screen to the inside of the computer.
  9. Toshiba Qosmio X305-Q704 Screen Replacement: 9 단계, 이미지 1/3 Toshiba Qosmio X305-Q704 Screen Replacement: 9 단계, 이미지 2/3 Toshiba Qosmio X305-Q704 Screen Replacement: 9 단계, 이미지 3/3
    • Remove the 6 mm screws holding the screen on to the laptop using a Phillips #0 screwdriver.
  10. Toshiba Qosmio X305-Q704 Screen Replacement: 10 단계, 이미지 1/2 Toshiba Qosmio X305-Q704 Screen Replacement: 10 단계, 이미지 2/2
    • Remove the screen from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Borden
회원 가입일: 03/08/19
220 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G1, Botvin Spring 2019 UMass Dartmouth, Team S1-G1, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G1
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 466
