주요 콘텐츠로 건너뛰기
Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement
필요한 것
  1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 2 단계, 이미지 1/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 2 단계, 이미지 2/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 2 단계, 이미지 3/3
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: 3 단계, 이미지 1/2 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: 3 단계, 이미지 2/2
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
  4. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: 4 단계, 이미지 1/2 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: 4 단계, 이미지 2/2
    • Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
  5. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 5 단계, 이미지 1/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 5 단계, 이미지 2/3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: 5 단계, 이미지 3/3
    • Next, use the pull tab to pull down and detach the hard drive from the connector.
    • Now the hard drive is loose and can be lifted straight out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Danielle Lapensee-Rankine
회원 가입일: 02/05/19
543 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 1,175
