소개
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
부품
부품은 필요하지 않습니다.
  1. Make sure the DVD player is unplugged before beginning.
    • Make sure the DVD player is unplugged before beginning.
    • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
  2. Turn the DVD player on its side. Remove the .303 inch screw.
    • Turn the DVD player on its side.
    • Remove the .303 inch screw.
    • Now flip the DVD player onto its other side.
    • Remove the .303 inch screw from this side.
  3. Flip the DVD player over onto it's front face.
    • Flip the DVD player over onto it's front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Flip the DVD player so its top is sitting on your working surface.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away each of the two tabs located in the middle of the player.
    • The front panel will not come off during this step, so do not force it.
  5. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Flip the DVD player on its side.
    • Flip the DVD player on its side.
    • Lift and slide forward a single tab on the side.
  7. Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
    • Grasp the front panel and pull forward and to your right to remove.
  8. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  9. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  10. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  11. Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
    • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  12. Lift disc drive vertically to remove.
    • Lift disc drive vertically to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joe Murphy
회원 가입일: 2011년 01월 20일
542 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G16
4 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 2,200
