주요 콘텐츠로 건너뛰기
Toshiba SD-K740 Front Flap Tray Door Spring Replacement
필요한 것
  1. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Top Panel: 1 단계, 이미지 1/1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 2 단계, 이미지 1/2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 2 단계, 이미지 2/2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 3 단계, 이미지 1/1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Panel: 4 단계, 이미지 1/1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 5 단계, 이미지 1/1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 6 단계, 이미지 1/2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 6 단계, 이미지 2/2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door: 7 단계, 이미지 1/2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door: 7 단계, 이미지 2/2
    • On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
    • There is just enough tolerance in the plastic to allow removal, be careful of brittle plastic.
  8. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 8 단계, 이미지 1/1
    • Once the peg is free from the left restraint, carefully remove the left part of the flap.
    • Carefully remove the right peg from the restraint.
    • Do not pull away from the front panel because the spring is still attached.
    • Do not force the plastic.
  9. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 9 단계, 이미지 1/1
    • Remove the spring from the end of the right peg by pulling the door away from the spring.
    • Do not pull away from the front panel until the spring has been removed from the flap.
  10. Toshiba SD-K740 Front Flap Tray Door Spring Replacement, Front Flap Tray Door Spring: 10 단계, 이미지 1/1
    • Remove the .384 inch screw holding the spring to front panel.
  11. Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 11 단계, 이미지 1/2 Toshiba SD-K740 Front Flap Tray Door Spring Replacement: 11 단계, 이미지 2/2
    • Slide the spring off of the underlying peg.
결론
John Lokker
회원 가입일: 01/20/11
324 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G16
4 회원들
안내서 8개 작성하였습니다
댓글 5개
Thanks for sharing,
It's very informative for me, I really enjoy this content.
I also have Content about <a href="https://accesssecuritygates.com/"> door spring replacement</a>
Cheers.
ali - 답글
Great Article's content. Its worth reading. What type of auto gate repair is best for you? Find out by comparing repair services, prices and tech info. If you're in need of automatic gate repair, <a href="https://www.ozgaragedoorsandgates.com/"#...>Oz Garage Doors And Gates</a> can be a solution.
ozee garage - 답글
I got wonderful content after reading your article. Thankyou for information. Find out by comparing repair services, prices and tech info. If you're in need of automatic gate repair, <a href="http://elitecommercialgaterepairs.com/"#/>Elite Commercial Gate Repairs</a> can be a solution.
nature nut - 답글
Thanks for this Article! If anyone looking for a platform which provide services of repairing ad installation doors. <a href="https://http://powermastergateopenerrepair.com/"...>Power Master Gate Opener Repair Specialist</a> can be a solution.
georgia oscar - 답글
Thanks for sharing us this informative article. If you're in need of automatic gate repair, <a href="https://http://miamioverheadgaterepair.com/"#/>Miami Overhead Gate Repair</a> can be a solution.
Ella Swan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,178
