소개
This guide gives instructions on how to remove the fuse located on the yellow motherboard of the Toshiba SD-K740 DVD player.
필요한 것
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
