주요 콘텐츠로 건너뛰기
Toshiba SD-K740 Motherboard Replacement
필요한 것
  1. Toshiba SD-K740 Motherboard Replacement, Top Panel: 1 단계, 이미지 1/1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Replacement: 2 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 2 단계, 이미지 2/2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Replacement: 3 단계, 이미지 1/1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Replacement, Front Panel: 4 단계, 이미지 1/1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Motherboard Replacement: 5 단계, 이미지 1/1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Motherboard Replacement: 6 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 6 단계, 이미지 2/2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Motherboard Replacement: 8 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the first of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  9. Toshiba SD-K740 Motherboard Replacement: 9 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the second of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  10. Toshiba SD-K740 Motherboard Replacement: 10 단계, 이미지 1/1
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force the cable. It should slide out with minimal force.
  11. Toshiba SD-K740 Motherboard Replacement: 11 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the first of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  12. Toshiba SD-K740 Motherboard Replacement: 12 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 12 단계, 이미지 2/2
    • Remove the second of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  13. Toshiba SD-K740 Motherboard Replacement: 13 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove the third of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  14. Toshiba SD-K740 Motherboard Replacement: 14 단계, 이미지 1/1
    • Flip the DVD player so it is resting on its front face (so the back is facing you).
    • Remove the four .320 inch screws holding the motherboard to its casing.
  15. Toshiba SD-K740 Motherboard Replacement: 15 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 15 단계, 이미지 2/2
    • Push the motherboard forward a few inches to detach it from the casing.
  16. Toshiba SD-K740 Motherboard Replacement: 16 단계, 이미지 1/2 Toshiba SD-K740 Motherboard Replacement: 16 단계, 이미지 2/2
    • Lift the motherboard from the rear and pull backward (towards you) to remove it entirely from the case.
결론
Joe Murphy
회원 가입일: 01/20/11
542 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-16, Amido Winter 2011 Cal Poly, Team 1-16, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G16
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 923
