주요 콘텐츠로 건너뛰기
Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
필요한 것
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 2 단계, 이미지 1/1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 3 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 3 단계, 이미지 2/2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 4 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 4 단계, 이미지 2/2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: 5 단계, 이미지 1/1
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 6 단계, 이미지 1/1
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 7 단계, 이미지 1/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 7 단계, 이미지 2/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: 7 단계, 이미지 3/3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 8 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 8 단계, 이미지 2/2
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 9 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 9 단계, 이미지 2/2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 10 단계, 이미지 1/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 10 단계, 이미지 2/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 10 단계, 이미지 3/3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: 11 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: 11 단계, 이미지 2/2
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 12 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 12 단계, 이미지 2/2
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: 13 단계, 이미지 1/1
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 14 단계, 이미지 1/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 14 단계, 이미지 2/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 14 단계, 이미지 3/3
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: 15 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: 15 단계, 이미지 2/2
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 16 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 16 단계, 이미지 2/2
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 17 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 17 단계, 이미지 2/2
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 18 단계, 이미지 1/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 18 단계, 이미지 2/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 18 단계, 이미지 3/3
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 19 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 19 단계, 이미지 2/2
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: 20 단계, 이미지 1/2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: 20 단계, 이미지 2/2
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 21 단계, 이미지 1/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 21 단계, 이미지 2/3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 21 단계, 이미지 3/3
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: 22 단계, 이미지 1/1
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kiril Lange
회원 가입일: 09/22/14
943 평판
안내서 9개 작성하였습니다
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 회원
USFT-BROWN-F14S3G2
3 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 881
