소개
An overheating laptop, or an always on noisy fan, can be caused by a clogged heatsink, clogged fan, broken fan, or bad thermal paste.
This procedure is similar to the Satellite 1410.
필요한 것
Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
Fully detach the strip.
Unscrew the screws on either side of the power button circuit board.
Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
Clean the old thermal paste off the CPU and heatsink.
Use a q tip to remove the majority of the thermal paste.
Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
Dry and clean both surfaces with another q-tip.
Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
다른 한 분이 해당 안내서를 완성하였습니다.
