주요 콘텐츠로 건너뛰기
Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
필요한 것
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 2 단계, 이미지 1/1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 3 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 3 단계, 이미지 2/2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 4 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 4 단계, 이미지 2/2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 5 단계, 이미지 1/3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 5 단계, 이미지 2/3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: 5 단계, 이미지 3/3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 6 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 6 단계, 이미지 2/2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 7 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 7 단계, 이미지 2/2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 8 단계, 이미지 1/3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 8 단계, 이미지 2/3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 8 단계, 이미지 3/3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: 9 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: 9 단계, 이미지 2/2
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 10 단계, 이미지 1/2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: 10 단계, 이미지 2/2
    • Pull upward on the small white ribbon cable to detach from circuit board.
결론
Kiril Lange
회원 가입일: 09/22/14
943 평판
안내서 9개 작성하였습니다
USF Tampa, Team 3-2, Brown Fall 2014 USF Tampa, Team 3-2, Brown Fall 2014 회원
USFT-BROWN-F14S3G2
3 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 24
전체 시간: 1,429
