주요 콘텐츠로 건너뛰기
Toshiba Satellite 1805-S177 Keyboard Replacement
필요한 것
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite 1805-S177 Keyboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite 1805-S177 Keyboard Replacement: 2 단계, 이미지 3/3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: 3 단계, 이미지 1/1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite 1805-S177 Keyboard Replacement: 4 단계, 이미지 2/2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
결론
Hannah
회원 가입일: 06/24/10
227 평판
안내서 7개 작성하였습니다
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G5
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,652
