주요 콘텐츠로 건너뛰기
Toshiba Satellite 1805-S177 RAM Replacement
필요한 것
  1. Toshiba Satellite 1805-S177 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite 1805-S177 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
  2. Toshiba Satellite 1805-S177 RAM Replacement: 2 단계, 이미지 1/1
    • Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
  3. Toshiba Satellite 1805-S177 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite 1805-S177 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite 1805-S177 RAM Replacement: 3 단계, 이미지 3/3
    • Using your fingers, push two shorter sides of RAM away from each other.
    • Note: The RAM should pop up automatically.
  4. Toshiba Satellite 1805-S177 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite 1805-S177 RAM Replacement: 4 단계, 이미지 2/2
    • Using your fingers, pull RAM out of the laptop by gentling lifting up.
    • When reinstalling ram be sure to line up the ram correctly with the slot and notch in the ram
결론
다른 4명이 해당 안내서를 완성하였습니다.
Hannah
회원 가입일: 06/24/10
227 평판
안내서 7개 작성하였습니다
Cal Poly, Team 3-5, Johann Summer 2010 Cal Poly, Team 3-5, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G5
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 2,759
