주요 콘텐츠로 건너뛰기
Toshiba Satellite 2430-S255 Battery Replacement
  1. Toshiba Satellite 2430-S255 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
  2. Toshiba Satellite 2430-S255 Battery Replacement: 2 단계, 이미지 1/1
    • Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
  3. Toshiba Satellite 2430-S255 Battery Replacement: 3 단계, 이미지 1/1
    • Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
결론
Jacob Zuliani
회원 가입일: 03/19/18
147 평판
안내서 1개 작성함
UMass Dartmouth, Team S6-G5, Bernier Spring 2018 UMass Dartmouth, Team S6-G5, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 209
