주요 콘텐츠로 건너뛰기
Toshiba Satellite 2435-S255 Battery Replacement
  1. Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: 1 단계, 이미지 1/2 Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: 1 단계, 이미지 2/2
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Battery Replacement, Remove the Battery: 2 단계, 이미지 1/1
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
결론
Jonathan Lancey
회원 가입일: 10/22/14
1 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-5, Shastany Fall 2014 UMass Dartmouth, Team 1-5, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G5
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 233
