주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4011 Battery Replacement
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A105-S4011 Battery Replacement: 2 단계, 이미지 2/2
    • Hold the release switch and pull out the battery towards you.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Lucas Salisbury
회원 가입일: 04/18/13
73 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 회원
CPSU-MANESS-S13S4G14
4 회원들
안내서 14개 작성하였습니다
댓글 2개
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - 답글
The part number is PSUB2U-00K00P
Benjamin Osei - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,254
