소개
This guide will help you take out the battery, and replace it with a new one. Changing the battery is easy and simple.
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
The part number is PSUB2U-00K00P
