주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4011 Hard Disk Drive Replacement
필요한 것
  1. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 2 단계, 이미지 2/2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Hard Disk Drive: 3 단계, 이미지 1/1
    • Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
    • You may want to ground yourself before attempting to touch any components. This means touching a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    • Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
  4. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 4 단계, 이미지 1/1
    • Once the screw is completely removed, pull back the plastic cover carefully.
    • If you are having trouble removing the cover, a plastic removal tool may be used.
  5. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: 5 단계, 이미지 1/1
    • Remove the hard disk by gently applying pressure with your thumb while sliding the hard disk to the left.
    • If you do not ground yourself, you run the risk of damaging your hard disk.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Connor Russell
회원 가입일: 04/18/13
49 평판
안내서 1개 작성함
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 회원
CPSU-MANESS-S13S4G14
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 25
전체 시간: 1,747
