이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
Once the screw is completely removed, pull back the plastic cover carefully.
Remove the hard disk by gently applying pressure with your thumb while sliding the hard disk to the left.
다른 4명이 해당 안내서를 완성하였습니다.
