소개
Replacing the keyboard will require some prying, but it does not take too many steps. (Note that the last step in this guide is not necessary to remove the keyboard, but IS necessary if you later would like to disconnect the display piece from the rest of laptop.)
부품
지정된 부품이 없습니다.
  1. Make sure to turn off the laptop, unplug the device and/or remove any batteries. Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on. Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
    • Make sure to turn off the laptop, unplug the device and/or remove any batteries.
    • Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
    • Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
    • Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
  2. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  3. Completely remove the plastic piece from the body of the laptop. Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.) Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.)
    • Completely remove the plastic piece from the body of the laptop.
    • Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.)
  4. Without yanking, lift the keyboard up carefully. Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop. Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop.
    • Without yanking, lift the keyboard up carefully.
    • Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lucas Salisbury
회원 가입일: 2013년 04월 18일
49 Reputation
안내서 3개 작성하였습니다
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 회원
CPSU-MANESS-S13S4G14
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,152
