주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4011 RAM Replacement
필요한 것
  1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4011 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite A105-S4011 RAM Replacement: 2 단계, 이미지 2/2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
    • This screw cannot be taken out, it is a "captive" screw.
  4. Toshiba Satellite A105-S4011 RAM Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
    • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
  5. Toshiba Satellite A105-S4011 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite A105-S4011 RAM Replacement: 5 단계, 이미지 2/2
    • Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
    • Grounding yourself may be a good idea before actually touching the RAM module. This entails touching a conductive metal in order to remove any excess static energy in your body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lucas Salisbury
회원 가입일: 04/18/13
73 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-14, Maness Spring 2013 Cal Poly, Team 4-14, Maness Spring 2013 회원
CPSU-MANESS-S13S4G14
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,219
