이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
다른 한 분이 해당 안내서를 완성하였습니다.
