이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
Completely remove the plastic piece from the body of the laptop.
Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.)
Without yanking, lift the keyboard up carefully.
Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop.
Turn the laptop over, so that you are now looking at the bottom of the laptop.
Using the Phillips #1 screwdriver remove the fourteen 6mm screws.
Using the Phillips #1 screwdriver remove the three 4mm screws.
Completely remove the display piece by pulling between the silver display-component and the black bottom-component. The display- component is an all-in-one component pictured here.
On the top half of the disassembled laptop (the part that is connected to the display) use the #1 Phillips Screw Driver to remove the four 5mm screws holding the speakers in place.
Once the screws have been removed, simply lift the two individual speakers out of their positions.
Once the speaker wires have been disconnected, the screws unscrewed, and the speakers removed you should be left with these two components.
다른 4명이 해당 안내서를 완성하였습니다.
