주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4074 Battery Replacement
필요한 것
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4074 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: 2 단계, 이미지 1/3 Toshiba Satellite A105-S4074 Battery Replacement: 2 단계, 이미지 2/3 Toshiba Satellite A105-S4074 Battery Replacement: 2 단계, 이미지 3/3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
결론
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Ryan Bortnick
회원 가입일: 03/20/17
722 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G1
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 10
전체 시간: 364
