소개
After diagnosing your Toshiba Satellite A105-S4074, should hard drive failure be imminent and replacement necessary, these easy to follow instructions will guide you through the process.
필요한 것
Turn the laptop around so that the battery slot is facing away from you, and locate the hard drive access panel in the lower left-hand corner.
Locate the hard drive access panel in the lower left-hand corner on the bottom of the laptop, and loosen the 4.0 mm screw in the top center of the panel using the Phillips #1 screwdriver.
Carefully remove the panel with your fingers by lifting the edge at the indent.
To reassemble your device after replacing the hard drive, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
