소개
Should the keyboard of your Toshiba Satellite A105-S4074 become non-responsive—one or more keys slow, stuck, or producing multiple characters; or the entire keyboard is not functioning—and need to be replaced, these easy to follow instructions will guide you through the process.
필요한 것
Turn the laptop back over so it is right-side up, with the cover facing up.
Open the laptop all the way so that the screen is horizontal with the body.
Using the iFixit plastic opening tool, pop up the left tab along the top of the panel that is connected to the hinge for the widescreen display.
Using the plastic opening tool, pop up the right tab along the top of the panel that is connected to the hinge for the widescreen display.
Pry up and remove the cover panel that is located above the keyboard.
Position laptop so that both screws connecting the keyboard to the laptop are visible.
Unscrew the left 3.0 mm screw that is holding the keyboard onto the laptop using the Phillips #0 screwdriver.
Unscrew the right 3.0 mm screw that is holding the keyboard onto the laptop using the Phillips #0 screwdriver.
To reassemble your device after replacing the keyboard, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
