주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
필요한 것
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: 1 단계, 이미지 2/2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 2 단계, 이미지 1/3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 2 단계, 이미지 2/3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 2 단계, 이미지 3/3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): 3 단계, 이미지 1/2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): 3 단계, 이미지 2/2
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 4 단계, 이미지 1/3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 4 단계, 이미지 2/3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: 4 단계, 이미지 3/3
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
결론
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Bortnick
회원 가입일: 03/20/17
722 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G1
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 565
