소개
After diagnosing your Toshiba Satellite A105-S4074, should you conclude that the optical disk drive has failed and will need to be replaced, these easy to follow instructions will guide you through the process.
필요한 것
Turn the laptop around with the battery slot facing away from you.
Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
