부품
부품은 필요하지 않습니다.
  1. Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker. Use the plastic opening tool to pop off tabs along the length of this panel. This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Lift the keyboard gently from the side closest the screen. Pull out the ribbon connecting the keyboard to the laptop. Pull out the ribbon connecting the keyboard to the laptop.
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  6. Disconnect wire attaching LCD to motherboard Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  7. Remove the seventeen 4.5mm phillips screws on the bottom of the laptop. Using the pry tool separate the two halves of the laptop base.
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  8. Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard. Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Josh
회원 가입일: 2014년 03월 12일
610 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-6, Cichon Spring 2014 University of Maryland, Team 1-6, Cichon Spring 2014 회원
UMD-CICHON-S14S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 607
