이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Lift the keyboard gently from the side closest the screen.
Pull out the ribbon connecting the keyboard to the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
